Old 22 Dec 2007, 05:52 pm
Nickatnite Nickatnite is offline
Default Instrument Cluster LAmps - Update . .
I had replaced the lamps in my cluster, put it all back together and had no highbeam indicator - turns out it was a bad bulb. So I took it apart again, only took me 50 min. this time! Practice makes perfect LOL) As I thought, there are only 6 lamps in the cluster. (See the photo below) I did learn a new trick this time. Instead of removing the lower side cover completely, I just took out the 2 screws, and very SLOWLY pulled it out from the right side until the instrument cluster bezel could be removed. The lower side panel stayed in the gasket eliminating the problem. (see the attached pictures) How this helps anyone who has to replace the lamps. Oh yah, one you get the cluster in don't just check your instrument panel lights, check your highbeam indicator . . . .
Nick
