Old 26 Dec 2007, 11:08 am
DJmart's Avatar
DJmart DJmart is offline
Send a message via AIM to DJmart
Default Re: Air horns and OEM horns? At the same time?
The way the switch works in the interior of the car for the airhorns is completing a circuit to ground....
The OEM horns are the same way.... one is a hot wire one is negative... which should I tap into without creating unnecessary voltage to the relay.....
two wire run to the OEM horns as it is, one hot one ground.....
One wire run to the relay and off the switch to negative..
thanks
