Old 27 Dec 2007, 12:02 am
Cartman Cartman is offline
Default Re: Standard Transmission 2001
It sounds like either your shifter is out of adjustment, or your clutch is failing to fully disengage. My money would be on your clutch. worn springs on your clutch would be the most obvious reason which would call for a new clutch. to a lesser extent the fluid in the clutch system could need changing. brake fluid (what the clutch system uses) soaks up moisture after a while and loses some of its effectiveness.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
