Old 27 Dec 2007, 12:53 am
Cartman Cartman is offline
Default Re: 04 pt cruiser stalls when put into drive
so i take it that the car idles fine, the problem only happens when you place the car in drive? does it die when you rev it in park or N? if it revs fine in park, its not the TPS.
Now this may not be related but you have to throw this into the maybe category. I was working on a mitsubishi galant that had the smae problem you are having. I found the same spark plug condition you had (bad plug, shorting straight to the head) after replacing the plugs and wires, i still couldnt keep it started. towed it to the dealer. apparently the ECM was messed up due tot he shorting of the plug (feedback or some such thing). now im not completely sure on that diagnosis, but hey, it can happen.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
