Old 27 Dec 2007, 07:29 am
CREWZIN CREWZIN is offline
Default Re: Opinions on Mopar high performance plug wires needed.
A couple of things. The first time I changed plugs and wires I used the Mopar Performance Wires that I got off eBay. They worked fine for over 20,000 miles and at that time I put on a chrome intake so since it was accessible, I changed the wires and plugs again this time using the Crane wires from Race & Street.
Both set of wires worked fine and I still have the same set of plugs and wires in with about 40,000 miles on them.
About the warranty. No matter what parts you use on your vehicle, weather they be Mopar or aftermarket, will not void your warranty unless it can be proven that the particular part had anything to do with the failure/problem that you have that the warranty came into play.
In other words, putting on lowering springs cannot be blamed for an engine failure, but might be the cause of suspension problems. Aftermarket wires won't and can't be blamed for a clutch failure or engine leak but could be the cause of internal engine failure if it was proved you might have done something wrong when you had the upper intake off while changing the wires. Bottom line, whatever part you use has to be proven to be the cause of the failure/problem to void any part of your warranty.
Here's a good interpretation of the ACT that covers warranties:
Keeping Your Mod's Warranty Intact - For Dummies
