Re: Vacuum line to control vent for outside & recirculate
The brake booster was the first area I looked at, but I couldn't see any line running into the cabin, and found no leaks. I also removed the heat shielding around the vacuum lines to check for leaks. I ran the car up on rhino ramps and crawled under to try and find a vacuum line going into the cabin- no luck!I have an 03 GT.As I stated before I also checked the climate control module, and the vac assist to the gate that controls inside/outside. One simple vacuum line, and I can't find it!
