Old 27 Dec 2007, 11:09 pm
Cartman Cartman is offline
Default Re: Air horns and OEM horns? At the same time?
Ok lets see if i can make a visual. YOu have 4 wires coming out of your relay. 2 are the switched (power tot he horns, one from the batt to the relay, one from the relay to the horn) 2 that are remote (power to the switch inside the relay). 1 remote terminal should be grounded. the other should be tapped into your OE horns pos(+) feed (i believe a green/red wire). the switched wires remain unaffected. wiring is a complex language that is best spelled out in diagrams, words can be confusing.
the way you have it now to my understanding (and correct me if im wrong here):
one of your remote wires is on a constant hot(+) and the other wire runs into the cabin, through a A/M button then to ground.
if only you werent on the opposite end of the country, id have that whole thing done for you in a sec.... oh well.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
