Re: 12.1" Flip Down Screen
as far as ive seen, every headliner mounted AV system requires a hole of some size to be cut. wires have to be run through, and some systems arent surface mount and require a square hole to be cut in order for the system to recess properly. maybe if you mounted the system over the existing dome lamp hole (if it is a flush mount system) you could avoid cutting a hole, youd just loose some interior illumination and have four small holes for the fasteners.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
