Re: Engine Won't Start -- Code P0129
Have you checked to see if youve pinched or broken any wires leading to/from the map sensor? if the wires are ok, you might have a bad PCM  . this is going by the diagnostic flow chart for code po129. if your car was able to run and you still had this code, the IAC system might have problems too.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
