Old 05 Jan 2008, 01:08 pm
CREWZIN CREWZIN is online now
Default Re: Something's busted -- right front undercarriage
Elliot,
The picture is too dark and small to see any detail.
We can all guess at what you bent, broke or tore up but the easiest way is just get it to any shop that does repair and have them take at look at it.
Oil is only in one place, your pan. You could have knocked a hole in the side and when the the oil was low enough, it stopped leaking or hit the oil filter so it's leaking from where it screws on. Sounds like you didn't drive the car. Did you start it up and see if the leak gets worse. Check the oil level before starting it.
Can't think of any rod that goes to the back of the car. Are you sure you didn't knock off the front sway bar from the right side and now it's pointing back towards the rear instead of going over to the left side?
