Side-Rear Fixed Window (the small ones) Wind Noise
There must be a leak in the seal. I was able to pull a piece of vinyl moulding that looks like maybe post manufacture spot welding. I could see no other evidence of a wreck but can not be sure.
Regardless, I see some small studs that are on what look like rubber mounts. I can probably get to all of those nuts and concievably pull the window, or...
I had considered using a sealant. Most silicone stuff has acetic acid which will likely promote rust.
Does anybody have any advice, exploded views or pictures?
Alldata has nothing. All searches make it appear that nobody know there are small fixed windows on PTs.
