Old 15 Jan 2008, 10:32 am
gevans gevans is offline
Default Changing wheel bearings, Press required?
Hello all. I have a 2003 Cruiser, the right front wheel bearing is showing some slop. I see behind the brake disc there are three or four bolts holding a plate on top of the wheel bearing. My question is, can I replace that bearing without a press? Does it just kinda fall out after I pull the plate? Or will I need to take it to a shop?
That will make the difference on whether I DIY or take it to the shop to start with.
Thanks all!
