Re: Skip stage 1 and go directly to stage 2?
Originally Posted by oldfashionedgent
, trottle body spacer, Save your money - it's worthlessBOV conversion kit and intake manifold heat sheild.??? What heat shield? If your '05 has the metal intake, get the composite intake - it flows better and doesn't heat soak
But what about fuel injectors?
The stage 1 only has them for the 2003 model! That's because the injectors were made larger in '04 on all turbos. The injectors you get for an '03 S1 are what you already have
If you're serious about performance, go to PTCrew.com - Learn it or Burn it. there are some gurus there.
