Old 22 Jan 2008, 11:28 pm
Cartman Cartman is offline
Default Re: Replacing power steering
its not too awful bad to do yourself. it does take a while though. take off the wheel, take off the shields. take off the belt. youll have to move the ac compressor out of the way (you dont have to disconnect the hoses), take off the grille of the car, unbolt the upper tie bar. pull the radiator and condenser assembly up off of its mounts and pull it as far forward as you can. then disconnect the power steering hoses ( a good crowsfoot set is needed) then unbolt the pump and pull it out through the top betweent he radiator and motor. then just reverse all that to put it all back in. its not bad at all really. i just had to do one not too long ago. took a while to figure out how to get the pump out of the car.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
