Re: New '03 PT , What to watch for?
It has 78, 000 km on it (I'm in Canada). So I should look at replacing:
Ignition Wires & Plugs (what are the signs that this needs to be done?)
Tires (will probably only do if they show signs of wear)
Brakes (same as above)
Auto Transmission Flush (I believe the dealer is doing this but I will check)
Timing Belt & Water pump (miles to km 160, 000 km? does that sound right?)
Anything else anyone can think of that I can budget for either to replace right way or for preventative maintenance? Anything that is known to be a problem part that I can have my mechanic keep an eye on when I go in for regular maintenance?
