Old 25 Jan 2008, 03:58 pm
CREWZIN CREWZIN is offline
Default Re: Heater and Missing since temps dipped in Ohio
Nothing like throwing parts at a problem with you paying the bill. If you were still under warranty, they would have found the problem and you'd be a happy owner.
As far as the missing, you can't rule out that it was just plain too darn cold for the PT, until you said you let it warm up. Did it ever do it again after that?
The first thing we always ask people is; what's your mileage and the last time plugs and wires were changed?
Lets see, new radiator, heater core and water pump. My suggestion is a new thermostat and to make sure the system is bled properly of air. Trapped air will cause a loss of heat in the interior.
