Old 25 Jan 2008, 04:08 pm
soonercruiser's Avatar
soonercruiser soonercruiser is online now
Cool Re: Heater and Missing since temps dipped in Ohio
Yup! Agree.
Thermostat is the likely culprit on no heat, and fairly inexpensive to fix...probably stuck open.
And if it's a 2001, the OEM spark wires are probably failing. It was 15 degrees here this morning in OKCity...and several mornings this winter...no problem with either PT. (just make sure you are sticking with the recommended 5-30 weight oil)
