Old 04 Feb 2008, 07:26 am
06PT 06PT is offline
Default Re: Front end link bushing replacement?
How interesting. Mine is an '06 and I've had quite the problem with the sway bar staying attached to the car!!! It's the very end part of the sway bar where it attaches to the control arm.
The initial problem started because I had a squeeking noise while I turned, they told me the lower control arm bushing needed replaced (in order to do that they have to take the swaybar off). They fixed the passenger side and all was fine until a short time later when the driver side started squeeking. Same thing, lower control arm bushing and they replaced that.
Then about 3 weeks later we started hearing a clunking noise, it ended up being the sway bar bolt had broken and the driver side was just hanging down so everytime we turn in one direction or went over a big pot whole or bump we heard that clunking noise, well that was because it was hitting something under there.
WELL GUESS WHAT....... yes you guessed it, the driver side is hanging down AGAIN!!!!!!!!!! What is up with this sway bar that it can't hold on?????? This morning I'm going to be making yet another call to the dealership.....
