Re: leaking coolant near transmission pan
good news. the leak stopped as quick as it started.
the leak started when i backed up the car up our steep inclined driveway - then turned it off right away. i'm wondering...is there's a coolant pressure check/release valve somewhere other than the one near the filler neck? could the coolant have burped/belched from the coolant recovery tank's overflow passage? ---because it was pretty much empty. however, at the radiator, the coolant level was and is still full.
this magical leak is puzzling.
gt model, modified airbox with cold air induction, magnecor plug wires, tyc b/up lenses, chrome grille kit, retro 3d taillights painted steel blue, buick-style portholes, nomad chevy trunk trim, blue interior light strips, and massive turned down diesel-type exhaust tip.
