Re: leaking coolant near transmission pan
I had a leak from the hose that was attached to the turbo metal coolant line, and it only leaked when the engine was rev'd. There are also 2 heater hoses going over the tranny. If the overflow bottle was empty that's not a good thing, as you are loosing coolant. First check the turbo coolant line between the air box and head (remove the air box), there is a sharp bend in the hose and if it feel vey soft, or if you rev the engine watch that area.
