Old 16 Feb 2008, 03:26 pm
pppt03turbo pppt03turbo is offline
Default it's a chevy nomad, no it's a pt cruiser, nomad?
hi all -
thought i'd share this.
just finished installing 3/4" chrome trim on the rear hatch.
if you want to do this too - you'll need to do the following:
buy a 12 foot roll 3/4" 3m chrome trim. $18.99 at pep boys.
cut 8 - 17" pieces.
start at the center. btw: each center piece needs to be cut and shortened to accomodate the wing portions of the chyrsler logo.
these 2 center pieces (technically 4) need to be 6" apart from each other.
move outward and space each additional trim piece 5-1/2". (the 5-1/2" spacing allows the last 2 outer pieces to fall perfectly next to your additional emblems, so cutting "to go through" the emblem is not needed.) see attached pics.
tip: do not press firmly on the trim pieces until you're happy with your spacing and vertical placements. once your satisfied with all the trim placements, press them down using a soft "wax" rag.
park your pt in the sun, or blast your new trim with a hairdryer to cure (lock in) the 3m adhesive.
i think there's a kit out there like this for $75-$85. cut it yourself - and $$save$$!
gt model, modified airbox with cold air induction, magnecor plug wires, tyc b/up lenses, chrome grille kit, retro 3d taillights painted steel blue, buick-style portholes, nomad chevy trunk trim, blue interior light strips, and massive turned down diesel-type exhaust tip.
