Re: Changing wheel bearings, Press required?
The hub/bearing is an assembly that is not servicable individually. The parts are available from a parts store or dealer, so you can check prices. The price your mechanic gave you isn't bad, unless you're short on cash, then it might as well be a million.
First, jack the car up on the bad side, second, remove the wheel, third, remove the brake caliper adapter which will take off the caliper/pads/adapter as an assembly. Adaptor is held on with 2 18mm screws going into the knuckle. Tie the assembly up to the spring with a piece of wire so that the brake hose is not taking the weight. remove the brake rotor and set aside. The axle nut is 1 1/4" and comes off next, good time to have air tools. The hub/bearing assembly is held to the steering knuckle on the inboard side by 3 screws. Screws are kinda tough to get to without a u-joint socket. Loosen and back the screws off about 1/8", but don't remove them. Soak down the hub flange on the outboard side with wd or the equivalent, give it a little time to work, then use a punch/drift and hammer to tap on the heads of the inboard screws to push the hub out of the knuckle. Do not try to aid removal of the hub by prying on it against the brake rotor backing plate. The backing plate will bend easily, then you'll hear a bunch of nasty scraping noises when you go down the road, you'll blame me for bad info, then take it to your mechanic where he'll bend the sheetmetal back into place, and charge you $400 to punish you for doing it yourself.......Takes a few minutes with a hoist, the right tools, and a little experience. Will probably take you a bit longer. Good luck with it!
P.S. the hub is NOT a press fit to the knuckle, no press required. Corrosion usually makes it seem like a lot tighter fit than it really is.
Reason: more info
