Old 17 Feb 2008, 04:02 pm
littleblueGT littleblueGT is offline
Default Re: leaking coolant near transmission pan
There are also 2 lines coming out of the turbo underneath, and can only be seen from under the car. I replaced the coolant hose several months ago as it felt soft, and I also placed foil around the hose as a heat shield. You will need Rhino ramps to even see them, and you will want to use regular hose clamps instead of the factory spring clamps. I suggest that every one who owns a turbo PT check the coolant hoses from the turbo, or risk burning up the motor, and being stuck in the middle of no where!
