Old 19 Feb 2008, 06:36 am
Default Re: No head or tail lights
You check the fuses under the hood, or just the ones inside? Behind the air cleaner there's a black plastic rectangle with more fuses.
Was the car in an accident? Wires may have been cut. After you check the fuses under the hood, get a meter and check for voltage at the light sockets.
Seems you already replaced the "multifunction switch" - which is the usual cause.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
