Re: easiest boost gauge to put in ?
Unless you are into the turbo you will not show boost. I have the Aeroforce as well as an Autometer C2 boost/vac gauge. The Aeroforce (very easy install) reads exactly the same as the Autometer gauge for vac and boost.
So in answer to the original question-the easiest install is the Aeroforce. When you take into consideration the other 30 readings you can get on the Aeroforce I would also say it is the cheapest as well.
2006-Black GT 5 speed-Stage1,Crane 8.5mm Wires,NGK 4306 plugs,Mopar BOV,AMXTTAB,Airbox mod&KN Drop In,Sirius,6 CD MGW shift Knob,RAS Grill,RAS Hoodlifts,Motostorm SS Emblems,HAWK Ceramic Brake Pads,Blackened Tails and Backup Lights,Black Painted Calipers,,Chrome headlight rings,rear SPT-4 and MOPAR billet badges otherwise debadadged, Aeroforce Interceptor and Autometer C2Boost/Vac gauge on custom billet base
