Old 28 Feb 2008, 08:08 pm
notnowles notnowles is offline
Default Re: Bad ball joint replacement?
I dropped both lower control arms on my 2002 (107K) and replaced the bushings with urethane bushings. I also changed the wheel bearings at the same time. (One of them had some wear).
I got the old bushings out by heating them up with a MAP gas torch. Kind of smelly and lots of black smoke!
I didn't have to press in the new bushings. They went in quite easily with the supplied thick and messy lubricant.
I decided to go with the aftermarket urethane bushings because it seems pretty obvious to me that the factory bushing is a problem at the rear of the arm (the vertical bushing). Seems like everyone has replaced them at least once if they have any significant miles on their cars at all.
The wheel bearings are a press job, but just your typical run of the mill set up, nothing exotic or unusually difficult.
The hardest part of the bushing job is getting things apart. I had to go slowly and use lots of penetrating oil and "back and forth" to get some of the bolts out w/o breaking.
The ball joints in my car were in perfect condition. I installed grease fittings in them to renew the lubricant. I may end up removing the fittings unless I can find some new boots for the ball joints that would let excess grease come out of the top. The original boots are not designed to let any grease exit, as the ball joints are designed to be maintenance free.
I have seen replacement ball joints listed on the web that I believe were designed to bolt in with a modification to the arm.
My sense is that the ball joints on the cars are pretty hardy, so just be sure yours really are bad. The vertical bushings on the control arms seem to be the
weak link in the chain.
Hope this helps.
