  #18 (permalink)
Old 02 Mar 2008, 01:29 pm
outfit's Avatar
outfit outfit is offline
Send a message via Yahoo to outfit Send a message via Skype™ to outfit
Default Re: Help on Installing LED Mirrors on My 06 Cruiser
Originally Posted by monkeyracer View Post
I was just thinking that if you wanted to, you could hook up both wires to a spst switch, and leave it on the blue position, but if you get pulled over or otherwise need to, switch it to amber.
This way you could show the cop that they are amber and he'll probably let you off with a warning...
What type of switch is that??? SPST Switch. You talking about running both the blue and white wire and connecting them to the Positive on the turn signal... I didnt know if you could.. But the switch would make sense..
Oh I was starting on " Project Mirrors " ... I found the Green wire with brown stripe ( on drivers side ).... but I went to the passenger side, pulled the kicker pannel...no wires....did i miss something?? I went back to Muth Mirrors directions...it says..
Wiring for the passenger side turn indicator is located in the passenger side kick panel. Carefully slice the tape that covers the large bundle of wires which are routed to the back of the vehicle. Here you will locate a
BROWN WIRE WITH
A RED STRIPE
. Test that wire to ensure it is the correct wire. Label that wire as‘passenger side turn’.
Wire
I am going to take pictures of each step so that other people can look at this for ref... Tryn to do my part..
Quit being Boring.... Do it your way....
