Originally Posted by jingks
I have an oil catch tank and I was wondering where install the catch can hoses? I know one goes on the PCV, but I don't know where the other one will go. Does it go on the driver side crack case breather? (the hose that goes to the stock air box) Or on the Intake manifold. And why would it go on the intake manifold if it doesn't go in the crack case breather.
Reason being I'm installing an aftermarket intake on a 04 GT H.O.
Thanks guys!
Install the catch can in between the pcv and intake manifold. If you are bound and determined to use a hot air intake then the second catch can goes in between the crank case and the intake.
