Old 04 Mar 2008, 06:41 am
Default Re: possible to fix wiring thats...
Dunno, but you stand a good chance of making it worse. Your best bet is to find a junkyard, cut the cable leading to the connector with plenty of slack, then strip and solder each wire - color-code matching.
Get heat shrink tubing, cut about 1" pieces and slide a piece on each wire - you slide it over the solder joint and heat it with a lighter or heat gun.
