Old 04 Mar 2008, 08:37 pm
lakersfan1 lakersfan1 is offline
Default Re: possible to fix wiring thats...
Most harness plugs have wire crimped to the end of a metal piece that is pressed into the plug body. Alot of times they will pull out the backside with a firm pull. Get some needlenose pliers and try pulling them out to find enough meat to solder to. Sounds like it can't get any worse.
If you solder, don't forget the flux.
