Old 04 Mar 2008, 09:31 pm
igloo0001 igloo0001 is offline
Default Electrical Nightmare
Hello to all , Thanks for any help.
2001 pt 5 speed 109766 miles original owner. i was getting the p0622 generator field control problem / p1594 voltage to high in charging system code on my cluster gauge, while i was in ny during my drive back to jersey ( 25 min) the vehicles wipers front n rear came on my lights went out and smoke came out from behind the instrument cluster near the top where it meets the top of the dash and the car turned off loss of complete power, after a tow home, my battery had leaked out so i replace the battery and generator i get power to everything but i dont get any crank , all the fuses and relays are good..
not sure if my wiring were fried , any help on cost of replacement on wiring or how to go about checking my current wiring .
ive had to replace the coil pack with plugs and wires recently other then that i had no work done to the vehicle in the past 6 months at which time ive had my timing belt done with no problems everything on the vehicle is factory ( base model)
