Originally Posted by Cartman
i dont see why you couldnt do it yourself. taking the control arms off is fairly simple. just make sure you have both wheels off the ground so you dont have tension ont he sway bar. when you get the control arms off, you can take them to a shop and have them press the ball joints and bushings off press in the new ones. that shouldnt cost very much at all. if you have a heavy duty ball joint press with a good assortment of adapters you can press everything on and off yourself.
I bought some and got the control arm off... without disconnecting the knuckle... I won't do the other side that way!
Anyhow my rear pivot looks like it is moulded into an insert/sleeve that is pressed into the control arm. To remove it the way Energy says I would have to destroy the old rubber while saving the bug sleeve that is pressed into the rear control arm pivot. I expect some rubber to stay and can only think I have to buff the rubber off? The replacements look very different from OEM. I have pics.
