  #31 (permalink)
Old 11 Mar 2008, 12:43 am
outfit's Avatar
outfit outfit is offline
Send a message via Yahoo to outfit Send a message via Skype™ to outfit
Default Re: Help on Installing LED Mirrors on My 06 Cruiser
Originally Posted by monkeyracer View Post
I think it will go pretty well, the hardest part wil be feeding the wire through the door jamb. I'm going to pull the mirror off and test what wire does what. There's 3, so one is probably a common point, and the other two are motor up/down, and motor left/right.
I already got the stereo and subs installed, but I'm going to make a custom box that fit's into the lower cargo shelf rails, and it will sit flush with the back seats folded down. This way, I can get bump, and still move stuff.
You know I ran a couple of test wire through and it was not bad... I pulled the rubber out of its grooves and used a wire hanger.. I didnt have an alum rod ...It could have been pure luck, you know how that goes..When you are talking about pulling the mirror off are you talking about the OEM one?? I wanted to pull that one and splice one wire at a time to see which does what.. Sorry if there are alot of questions, I am not to experienced at this type of install.... Car stereo,amp, mechanical more my thing....
Quit being Boring.... Do it your way....
