Re: Help on Installing LED Mirrors on My 06 Cruiser
Had my door pannel off yesterday and looked at the problem. Think I will try to test and hook up the LED mirror under the steering wheel and hook into the 4 way flasher area but using the left and right turn signal wires. I think all the 4 way flasher does is use all of the wires. You can test the LEDs and see the colors by holding the wires on your battery, there is 1 ground wire and 1 wire each for each of the 3 colors. Looks easy, just need to do it.
E. White
