There are couple bolts underneath. right by the door. there are 2 bolts then when you open the hood there are 3 or 4 bolts holding it down. then u have to go under the car and there is a couple bolts holding the front of the fender on. it should be right behind and underneath the light assembly. You might have to take the light out. make sure you don't pull it off to hard and don't bend it. one little bend and the whole fender and the
fender flares will be not aligned and your car door will rub against it. Hope It works. Goodluck!!
