Old 15 Mar 2008, 07:06 am
CREWZIN CREWZIN is offline
Default Re: check engine light
Originally Posted by alvin201 View Post
Does the "check codes" feature also work on the 2007s? I tried it once and nothing came up.
Alvin,
If no codes are present, then the word "done" will appear in the center dial. That will prove you did the "trick" correctly. Someone on another thread said they retrieved the codes by pressing in the mileage reset button while turning the key to the ON position. On the older PT's this "trick" will only test all the dials and numbers, but the person who did it said the codes also came up at the end of the dial test, so try that one on your newer PT.
2000 PT. 96K miles, Original Owner
