Old 17 Mar 2008, 01:27 pm
cleverklutz cleverklutz is offline
Default Re: We're 16 hours into the engine and it's not out
Is your car a turbo or a N/A? The turbo engine is a non-contact engine, the valves can't contact the pistons if the timing belt breaks. The N/A engine is a contact engine, if the belt breaks the valves can hit the pistons. This is because the N/A motor has higher compression ratio and taller pistons. If valves did hit you should see marks on the piston(s) and also bent valves. If there's a machine shop that specializes in head work it might be an idea to bring the head in and have the valve seals changed and everything checked out. Then you have some piece of mind.
Ben
2001 Red PT Cruiser Limited, 16" OEM alloys, Heart Throb dual exhaust, Airaid CAI, Screamin' Demon coil and Livewires, some shiny stuff inside, Alpine deck, Alpine four channel amp, Alpine PLT5 sub, Hertz speakers in 4 corners, new stone chips every day to add character.
2007 Suzuki King Quad 700 4x4 for when the road gets bumpy.
