  #16 (permalink)
Old 19 Mar 2008, 09:06 pm
JaviPTGT's Avatar
JaviPTGT JaviPTGT is offline
Send a message via Yahoo to JaviPTGT
Cool Re: Piggyback Computer
Originally Posted by fastmdpt View Post
Go here,,SCT Automotive Performance Products
Then let me know if you are interested,, AJ Berge (A&A Motorsports LI NY) is working with me and SCT on my PT. There is no official PT support now, AJ and I met the owner Chris Johnson while we were at the PRI show, and he was amazed by the numbers my car put down,, on a fresh (tight) motor, untuned at low boost. AJ is an extremely talented tech, ( Viper certified) and takes great pride in his work. We are taking the SCT tuner in slow deliberate steps, but so far the changes we have made have been successful. AJ knows the Mopar PCMs inside and out. the NGC ( Next Generation Controller) is still being cracked, but AJ has a real good understanding of the PCM. I believe the flash unit is somewhere around $600, can be loaded with three separate tunes, and when you flash the PCM it downloads the "stock" configuration so you can return it back to stock if you need to.
Tom
dam $600 thats a lot of money i'm going to get stage 1 first then i'll see if i can spend $600 on the SCT thanks
