Old 23 Mar 2008, 06:42 am
Davestone Davestone is offline
Default Re: rough idle on 01 2.4
Thanx,it seems there is a real problem with plugs on these pt's,they must be sensitive.The hood said .050,but they came gapped at .040.We regapped and no it didn't change anything.I might add this is serious gas dumping,and we have checked every connector and even pulled them and checked the pins.I'll be getting the codes today, i really don't wanna tear it down to check the timing, that was a nightmare,and p.s. i wouldn't try changing the timing belt alone, get help, you cannot get that engine in the right angle to get the brackets off by yourself!
