Old 24 Mar 2008, 06:02 pm
CREWZIN CREWZIN is offline
Default Re: Engine Light on P0139 code
Your code if for the downstream oxygen sensor which is located on the left side of the catalytic converter. Trace the electrical lead from the sensor to the electrical connector and disconnect it. Unscrew the sensor with a suitable wrench (it's not necessary to use a special 02 sensor socket.
Forget the dealer and either do it yourself or ask around for a trusted mechanic.
