Old 26 Mar 2008, 09:24 pm
lakersfan1 lakersfan1 is offline
Default Re: Need some help with brake system
1) Since you took off a line, you will need to bleed all four corners as removing the line provided opportunity for air to get deep into the system. Start with the farthest line from the brake booster working to the closest corner.
2) The air will tend to try to stay at the highest point in the line, which is not the calipers in any car I've ever seen. It's usually at at a bend in the flex line to the caliper. Because of this, you will need to flush ALOT to get the air out of the line.
You can easily go through a large bottle of brake fluid bleeding all four corners FYI.
