Re: Changing wheel bearings, Press required?
Sorry, been on vacation out of state. couldn't get the hub out of the knuckle?
Did you remove the axle nut from the axle? Soak the area between the knuckle and the bearing/ hub assembly with penetrating oil(WD or the like), then work it out. Learned long ago that for most things mechanical, if you have to beat it with a hammer, something else is wrong and you need to take a closer look. Hope it worked out, probably not much help a week after you posted.
