Re: Intake Selection
The airraid sounds good, but I'm not too thrilled by the fit and finish. It leaves big gaps where it seals with the airbox. I can post pics if you'd like. I think it can still suck hot air, but then again so could the stock intake. I'm thinking I'll try going back with the stock airbox and modding it quite a bit. I want to do a ram air setup with a cheap hoodscoop, which will be a true cold air intake. If I utilize the stock air inlet on the airbox and rotate it 180* then I shouldn't have to worry about moisture from rain and such as the air will enter under the filter and go up. I have to check if I can remove that nose that goes over the battery, I want the intake to sound as good as the airraid.
Ben
2001 Red PT Cruiser Limited, 16" OEM alloys, Heart Throb dual exhaust, Airaid CAI, Screamin' Demon coil and Livewires, some shiny stuff inside, Alpine deck, Alpine four channel amp, Alpine PLT5 sub, Hertz speakers in 4 corners, new stone chips every day to add character.
2007 Suzuki King Quad 700 4x4 for when the road gets bumpy.
