  #11 (permalink)
Old 29 Mar 2008, 01:01 pm
pt102 pt102 is offline
Default Re: Changing wheel bearings, Press required?
Thank you for your reply 37. I put it back together w/ no changes- had to go to work. Glad to hear about your vacation. How was it?
From what I read subsequently, the hub must be pulled 1st with a special remover. Will try my slide hammer or break down and get a puller. Kinda like a harmonic balancer/ steering wheel 3 bolt puller with elongated fingers. You can't knock it out reverse. Then the bearing will come out. New bearing then goes on the hub and reinstall.
I hope I'm on the right track. There are no books available around here- chiltons or otherwise. Where are the good old days of separate bearings and races
TIA for your help.
