Re: P0700 Transmission Control System Malfunction
P0700 is a pcm trouble code that basicly says there is more trouble codes in the trans controler side of the pcm.
in order to find out what those codes are you will need a scan tool and then once you have the codes further diagnois can be done.
depending on what codes come out of the trans controler it could mean something simple like a bad speed sensor or some kinda bad like a loss of prime. gear ratio error codes can be caused by faulty sensors.
Best advice take it to either a dealer you trust or a tranny shop you can trust. if your not comfortable driving it get it towed.
whats the oil condition? does it smell burnt and is it dark in color? and is the level correct
