Re: Changing sparkplugs Question?
I removed the EGR tube on the back of the intake, and loosened the bolt on the bottom of the throttle body as well. I don't think you can tilt the intake with the EGR in place. The 13mm (I think, the big one...) bolt on the egr gave me grief when putting it back in. The hole it goes into has a metal insert that goes into a rubber grommet. It wasn't letting me thread the bolt in. I found it works like a charm if you take the grommet out, push the metal insert into it, and then just hold the grommet up to the intake as you thread the bolt in. It allows you more room to wiggle the bolt into the threads. If it gives problems you'll see what I mean.
Ben
2001 Red PT Cruiser Limited, 16" OEM alloys, Heart Throb dual exhaust, Airaid CAI, Screamin' Demon coil and Livewires, some shiny stuff inside, Alpine deck, Alpine four channel amp, Alpine PLT5 sub, Hertz speakers in 4 corners, new stone chips every day to add character.
2007 Suzuki King Quad 700 4x4 for when the road gets bumpy.
