Thread: Bypass the cat?
Old 31 Mar 2008, 11:21 am
cleverklutz cleverklutz is offline
Default Re: Bypass the cat?
To an extent if you remove restriction from the intake, the head, or the exhaust you'll pick up "free horsepower." An engine is often compared to a big air pump, make the air go in, through, and out easier, you'll improve efficiency.
I previously had a 1993 Dodge Dynasty with a 3.3L engine. I put in a test pipe, removed the muffler, and ran a 2 1/4" diesel resonator. I gained a second in my 0-60 time. My brother has a 1994 New Yorker. His trip computer showed he gained 2 mpg when he pulled the cats out of the exhaust.
I'm thinking there are gains to be had on my car pulling the cat. Keep in mind mine is N/A tho. I'll check into the bylaws here, and if it's all good I'll try it.
Ben
2001 Red PT Cruiser Limited, 16" OEM alloys, Heart Throb dual exhaust, Airaid CAI, Screamin' Demon coil and Livewires, some shiny stuff inside, Alpine deck, Alpine four channel amp, Alpine PLT5 sub, Hertz speakers in 4 corners, new stone chips every day to add character.
2007 Suzuki King Quad 700 4x4 for when the road gets bumpy.
