Old 31 Mar 2008, 08:21 pm
lakersfan1 lakersfan1 is offline
Default Re: where to put a amp??
If you crossover the sub properly, a small cavity shouldn't matter much. It'll probably raise the QTS and FS so high your F3 will probably be about 200 HZ, but rear speakers aren't meant to do much but do a little rear fill and shut your rear passengers up. Most of the sound should come from the fronts and sub.
