Old 31 Mar 2008, 09:23 pm
Mean Green Mean Green is offline
Default Re: Sway bars worth it?
Originally Posted by lakersfan1 View Post
I'm only adding a rear for now when I get around to putting my coilovers on. The stock bar is thicker than the aftermarket bars (though probably a lower grade of steel, but probably close to equal of aftermarkets that fact taken into consideration.)
Rear is the most sensible first addition anyways, as this is the way to fix understeer on a front wheel drive car. The one I ordered is adjustable, so I should be able to dial in neutrality.
Everyone I know of who has installed aftermarket sway bars like Progress and Eibach have been very happy with the aftermarket ones. Interesting you think the stock bars are thicker.
What year is your PT as starting in '03 the PT came witthout any rear sway bar? Adding a rear sway bar on a '03 on up means you have to buy the fasteners to install.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
