Originally Posted by 88budman
How does your car run with the Jet Chip. I was thinking of getting one but wanted to see how much difference it actually made before spending the money.
Not even close to the Mopar Stage 1. Even though the Mopar Stage 1 is more expensive it is the building block to more power. With the Jet chip you will still get an overboost code if you try and raise the boost even to 15 psi (Mopar Stage 1 level). With the Mopar Stage 1 you can raise the boost to 18 psi and get no code and have enough fuel to do so.
